Firmware CP 8831 3PCC
christianbernal
Good day!!
One question, I try to change the firmware to Cisco 8831 for this "cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn" for connecto to other vendor PBX.
But way CUCM OS Administration --> Software Upgrades --> Install/Upgrade not is possible the firmware don´t appear in the list.
I try with url page http://<dirección_IP_del_teléfono>/upgrade?tftp://<dirección_IP_del_servidor_TFTP>/<archivo_binario_del_firmware>
http://10.118.49.41/admin/upgrade?tftp://10.127.3.73/cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn
10.118.49.41 IP Address CP 8831
10.127.3.73 IP my host TFTP Server.
Firmware: cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn
But show the next error:
Actually the CP 8831 have the firmware:
Active Load ID: sip8831.10-3-1-1
How I changed the firware for CP8831 ??
8 Replies 8
HARIS_HUSSAIN
Check you tftp path i believe it is not pouting correctly. Just upload any other Firmware image and see if that pop up via tftp.
Please rate and mark correct answers<<
Rob Huffman
Hi Christian,
My understanding here is that once an 8831 has been configured with Cisco "enterprise" (standard) firmware it can no longer be converted to use 3pcc firmware;
Upgrade from Third-Party Call Control to Enterprise Firmware
You can upgrade phones from the third-party call control firmware to the enterprise firmware.
Caution
After you upgrade to the enterprise firmware, you cannot revert to the third-party call control firmware.
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/3PCC/firmware/9-3-4-sr2/cs38_b_phone-8831-3pcc-release-934sr2.html#task_98936B6D56E12D7431B7FF70EB1C0303
Cheers!
Rob
In this moment the CP8831 it is registered with the CUCM,
Then it is not possible? I need a new endpoint for this?
Hi Christian,
Sadly yes, that is my understanding here my friend.
Cheers!
Rob
from what I'm seeing, we cannot upgrade Enterprise firmware to third Party Call Control firmware. but reading the link, I don't see the caution or warning on the page? are they allowing it now? :D
just wondering
Caution
From;
skurczodyna
Would a hard/factory reset solve this issue?
you might try reading the following discussion:
https://supportforums.cisco.com/discussion/12429241/8831-factory-reset
A hard/factory reset will not solve the issue. Once the phone is locked to an Enterprise firmware it is there to stay.
Following an update of my Cisco CP-8861 3PCC to a firmware version 11.0.1 MPP, I have the screen with a white background.
I want to go back to a previous firmware previous to version 11.0.0, I'm looking for the firmware sip88xx.10-3-1-9-3PCC for CP-88XX 3PCC containing the following files:
fbi88xx.10-3-1-9-3PCC.sbn
kern88xx.10-3-1-9-3PCC.sbn
rootfs88xx.10-3-1-9-3PCC.sbn
sb288xx.10-3-1-9-3PCC.sbn
sip88xx.10-3-1-9-3PCC.loads
vc488xx.10-3-1-9-3PCC.sbn
I'm calling for your help can anyone among you have the sip88xx.10-3-1-9-3PCC firmware I need?
Thanks for your help !
