Hi All,
I have configured the WSA with WCCP id 1. I have one realm, one identity, and 4 access groups which match 4 security groups in AD.
Policy trace when going to a blocked category for a particular user seems to work as expected and says request is blocked. However, the machine lets said users view the site normally instead of blocking.
Looking at tail 1 logs I'm getting nada. WCCP statistics show no packet redirection.
I have configured the Core switch as follows
ip wccp source-interface Vlan105
ip wccp 1 redirect-list Cisco_Ironport group-list 99
interface Vlan4
description $DATA_NETWORK$
ip address 10.10.30.254 255.255.255.0 secondary
ip address 10.10.10.254 255.255.255.0 secondary
ip address 10.10.4.254 255.255.255.0
no ip redirects
ip wccp 1 redirect out
I also set up the CDA with passphrases that tests fine.
Any idea why redirection isn't happening? My first thought is the secondary addresses but a CCIE advised that should be okay. My next step is to remove the secondary addresses from vlan 4 to see if that is causing an issue. Ideas anyone?????
