ICM Internet Script Editor Errors
Oct 21st, 2016
We have UCCE 9.0(3) and are trying to use Internet Script Editor as we have multiple administrators.  It is enabled in the AW setup, but currently we are not able to connect via port 80 or port 443.  IIS is running on the AW, and I have tested this trying to connect using the host name as well as the IP and get the same results.
The error message received when checking 'Encrypted' and using port 443:  'Cannot communicate with Web server'
The error message received when disabling 'Encrypted and using port 80: 'Web server access forbidden'
These messages are received from any station that we've attempted this on.  Any thoughts?
Seth Tavis Mon, 10/24/2016 - 10:24
Yes; I am able to reach both of our HDS servers via telnet on ports 443 and 80.
david_legrand Thu, 02/16/2017 - 02:49
I am facing the same (PCCE 11.5). It works if I run Internet Script Editor with the account I have used for the install / config.
But not with an administrator created through CCEAdmin.
David
