10-24-2016 10:07 AM - edited 03-05-2019 07:20 AM
Hello ...
Hopefully a quick simple question.
Migrated from a Juniper SSG5 to Cisco RV325 and need guidance
on Port Mapping.
Incoming communication from a web-client comes in on
TCP port 80 (IIS) and port 26000 (accesses a DLL).
Need to port map the external 26000 port to an internal
port 26001.
I have tried PAT with no luck.
Thanks in advance for your time.
Best Regards,
... Clay
10-24-2016 11:58 PM
Hello Clay,
under the Service Management tab, you can add a service and specify the external and internal ports. In the link below, scroll down to about the middle of the document:
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=5b8b8dbc749d4c5ea96b680002e087f3_Configure_Port_Address_Translation__PAT__on_RV320_Router.xml&pid=2&converted=0
10-25-2016 08:22 AM
Hello gpauwan - thank you for your response.
I followed the instructions but am still having an issue getting the port to forward.
My process has been:
1. Create a firewall rule to allow WAN TCP port 26000 to Private IP 192.168.1.10.
2. Create a new Service called TEST as TCP protocol, External port 26000 and Internal Port 26001.
3. Goto Port Address Translation and add in the new service.
4. Save everything.
Is there a way to confirm this is routing? Might I turn on logging and that would help.
Thanks again - Best Regards, Clay.
