10-25-2016 10:42 AM - edited 03-05-2019 07:20 AM
(config)# crypto isakmp aggressive-mode disable
Thanks in Advance!
Daniel
10-26-2016 01:19 AM
crypto isakmp aggressive-mode disable is single global command which will disable AM mode for all ipsec vpn.
Kindly rate for useful post
10-26-2016 02:52 PM
Thanks Pawan!,
So what would be the impact on those ipsec vpn's? will they go down until I disable aggressive mode on the far ends?
10-26-2016 09:28 PM
Remote end should forceup for Main mode to get vpn up.
10-27-2016 08:38 AM
Ok
Thanks!
07-10-2017 12:35 AM
I have the same requirement, so will this bring down the ipsec vpn and auto re-establish, or do I have to do something on the both sides of the vpn to make it work again.
Please note that on one side aggressive mode has already been disabled.
