Warning message
How to configure SPA112 so that door buzzer also rings in the condo
I'm in an older condo and the door is wired directly into the apartment.  If I put an analog phone on the lines in the house, it rings and we can talk to the person at the door.  When I plugged the SPA112 into the lines in the house the buzzer doesn't work anymore.  What happens at the door is the dialer hears the beeps that indicate the door is sending a ring to the condo.  Then there's a click and a dial-tone.  In the condo the phone hasn't rung.
The following is a debug session of this interaction with the door.  What I'd like to know is, what does the stuff in the debug log mean (System only at debug level with one call in from the door)  and how can I configure the SPA112 to ignore/pass through/enable the call from the door?
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd 5, EP 2, ParameterType 27, ParameterValue 20
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd - 5, response 8
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd 5, EP 2, ParameterType 26, ParameterValue 30
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd 2
Oct 23 23:37:16 SPA112 user.notice sprvoip: Seq Num 69
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd - 2, response 2
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd 10, EP 2, Node ID 0
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd - 10, response 10
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd 14, NodeId 0
Oct 23 23:37:16 SPA112 user.notice sprvoip: cmd - 14, response 18
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd 16, NodeId 2
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd - 16, response 20
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd 14, NodeId 0
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd - 14, response 18
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd 12, NodeId 0
Oct 23 23:37:19 SPA112 user.notice sprvoip: cmd - 12, response 14
Oct 23 23:37:39 SPA112 daemon.info system[116]: MemTotal: 28416 kB
Oct 23 23:37:41 SPA112 daemon.info system[116]: MemFree: 9688 kB
Thank you
Daniele Giordano Mon, 03/13/2017 - 04:47
  • Gold, 750 points or more
The door line emulates an FXS line (provide power and signal). Also the SPA emulates an FXS line. This is the issue.
Two FXS lines "cannot talk" togheter.
An FXS line can talk with an FXO line (received power and signals) but the setup of an FXO equipment required a fine tuning to work perfectly.
Regards.
Related Content
