I'm using the NAM profile editor to create a NAM supplicant that will work with same settings as current Windows supplicant. I have problems with applying the PEAP properties from the Windows supplicant. I can't find the options "Connect to these servers" in the editor ?
The option "Trust any Root Certificate Authority (CA) installed on the OS" is chosen in the editor. I guess that should be sufficient to trust the enterprise root CA when the machines have been connected with the Windows supplicant before ? Or do I need to import this certificate into the editor ?
