10-26-2016 12:25 AM - edited 07-05-2021 06:02 AM
I see the below error on my Cisco Prime from one of the controller , i have multicast disabled on this controller.
CPU Receive Multicast Queue is full on Controller
Solved! Go to Solution.
10-26-2016 12:58 AM
There are a lot of threads on this error, have you looked at them? Many mentioned code being the issue but they also didn't have any user experience impact.
-Scott
10-26-2016 12:58 AM
-Scott
10-26-2016 02:31 AM
you are right there is no impact on users, but i need to work on it to avoid this error in future, i don't see anywhere solution for this problem anywhere
10-26-2016 02:35 AM
What code are you running on the controller. That is what you should look at when referencing the other posts. Bottom line is, if you ever upgrade or downgrade and stop seeing that error, you know you hit that bug which is probably cosmetic. You can always search also in the big tool to see if it's the code your runnin or open a TAC case to confirm if it's a bug in your case and the fix.
-Scott
*** Please rate helpful posts **+
