10-26-2016 10:13 AM - edited 03-17-2019 08:29 AM
I'm in a lab environment and I'm configuring an ISR 4321 using MGCP protocol.
My ISR has a NIM-1MFT-T1/E1 module which is currently down (I don't have an operator link my lab).
The problem is TFTP download failed on my router :
router#sh ccm-manager
MGCP Domain Name: router.local
Priority Status Host
Primary Registered 192.168.X.X
First Backup Backup Ready 192.168.X.X
Second Backup None
Current active Call Manager: 192.168.X.X
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 19:03:03 CEST Oct 26 2016 (elapsed time: 00:00:06)
Last MGCP traffic time: 19:03:03 CEST Oct 26 2016 (elapsed time: 00:00:06)
Last failover time: 19:01:10 CEST Oct 26 2016 from (192.168.X.X)
Last switchback time: 19:01:55 CEST Oct 26 2016 from (192.168.X.X)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 192.168.X.X
Current Link State: OPEN
Statistics:
Packets recvd: 2
Recv failures: 0
Packets xmitted: 1
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 1, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 3
Download Successful : 0
Download Failed : 0
TFTP Download Failed : 71
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
FAX mode: disable
Configuration Error History:
Is that normal that TFTP Download failed if my port is down?
IOS version : 03.16.04b.S
CUCM version : 11.5.1.11900-26
Thank you in advance for your answer.
Thomas.
Solved! Go to Solution.
10-27-2016 12:01 AM
Hi Thomas,
Couple of links to verify the config specially related to the "ip tftp source-interface" command
https://supportforums.cisco.com/discussion/12723521/cisco-isr-4321-cannot-download-mgcp-xml-configuration-files
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4gen-t1-e1-nim-guide.html
Manish
10-27-2016 12:01 AM
Hi Thomas,
Manish
10-27-2016 12:15 AM
Hello Manish,
Thank you!
The command "ip tftp source-interface" was indeed missing.
Now it works fine.
Have a good day.
Thomas.
