10-27-2016 04:53 PM - edited 03-08-2019 07:57 AM
A supplier is offering a CISCO WS-C2960X-48FPD-L switches. Does this model support UPOE technology?
Solved! Go to Solution.
10-27-2016 05:53 PM
Hi Martin,
No,WS-C2960X-48FPD-L is POE+ (IEEE 802.3at)switch.
maximum available power on a port is 30w .Have a look at the link provided on the previous reply and notice that you wouldn't have enough power on the PSU to power up all 48 ports as well
Cheers
Prabath
10-27-2016 05:44 PM
It doesn't support UPOE based on the link below. Also, when you go the URL, click Compare Catalyst 2960-X and Catalyst 3650 and you'll see a pdf that shows which switch supports UPOE.
http://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/models-comparison.html
HTH.
Please rate and mark the comment if you found it helpful.
10-27-2016 05:53 PM
Hi Martin,
Cheers
Prabath
10-28-2016 03:08 AM
Thks,
