Multiple IOS mages in BOOTVAR string ASA 5500 series
goodwinag
We have an ASA that is our main firewall, when typing the show bootvar command, the following output appears:
BOOT variable = disk0:/asa961-smp-k8.bin;disk0:/asa931-1-smp-k8.bin;disk0:/asa931-1-smp-k8.bin;disk0:/asa921-smp-k8.bin
Current BOOT variable = disk0:/asa961-smp-k8.bin;disk0:/asa931-1-smp-k8.bin;disk0:/asa922-4-smp-k8.bin;disk0:/asa921-smp-k8.bin
We would like to have the first one in the string as the boot image, would removing the remaining images be as simple as follows?
no boot disk0:/asa931-1-smp-k8.bin
no boot disk0:/asa931-1-smp-k8.bin (duplicate)
no boot disk0:/asa921-smp-k8.bin
After doing so, would the above mentioned images be removed from the bootvar?
Thanks In Advance,
Tony
Anton Abik
Level 4
Level 4
  1. just execute show run boot
  2. copy the output of this command. You will see something like this "boot system disk0:/asaXXX-smp-k8.bin" multiple times for every image
  3. put down "NO" before every image you dont want, like this "no boot system disk0:/asaXXX-smp-k8.bin"
  4. Leave just the one you want
  5. copy run start
Hope it helps
Anton Abik
Level 4
Level 4
  5. copy run start
Hope it helps
