GLC-LH-SMD still offer same compatability with other existing Cisco equipment?
synergicomp
 I need a confirmation from Cisco that –GLC-LH-SMD SFP IS COMPATIBLE with Cisco EHWIC-1GE-SFP-CU and Cisco Router 1921/K9.
If the use of –SMD requires additional licenses on 1921/K9 or different 1921/K9 Firmware we CANNOT accept the change from original/EOL GLC-LH-SM
Collin Clark
You should be good to go and no additional license required for DOM.
Palani Mohan
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix is the authoritative document from Cisco, that I could locate. It goes to state GLC-LH-SMD is meant to work with HWIC-1GE-SFP (15.0(1)M onwards) & EHWIC-1GE-SFP-CU (15.1(4M) onwards).
For this platform, licensing does not govern use of SFP.
Do you have this and it is not working? OR are you concerned about End-of-Sale and End-of-Life Announcement for the Select Cisco Gigabit Ethernet SFP Modules ? What is your specific concern?
Asking questions to better understand what is of concern to you. Once that is understood, I will do my best to address them.
Kind regards ... Palani
