11-01-2016 03:20 PM - edited 03-18-2019 06:32 AM
I have several MX300s running TC7.3.6.
They are all registered to CUCM and use TMS as the alternate phone book server.
Can you tell me how to turn off the upcoming meetings displayed on the screen?
The MX800s have a field in CUCM for OSD - Todays' Booking on/off, but not the MX300s
thx,
rob
Solved! Go to Solution.
11-09-2016 07:13 AM
Just because the command is there for the MX800 doesn't mean it supports it, the TodaysBooking configuration is only supported on the older codecs that run TC software. There isn't a way to turn off the OSD indicator for upcoming meetings, your only option is to use a custom wallpaper which will remove parts of the OSD such as the clock and list of upcoming meetings.
11-09-2016 07:13 AM
11-09-2016 07:16 AM
11-09-2016 07:28 AM
Interesting, as it's not mentioned in the admin guides as a configurable option, and since all the TC7 API guides aren't listed on the website anymore I can check.
