2811 - Problem with boot "cannot load flash"
Christian Maus
Hi Community,
i have some problems to use my cisco c2811 router. After accidentley deleting the flash:/.bin file, my IOS is not available anymore. For that reason, after restart, the router is in a continous loop with boot: cannot fload "flash"
Is there any possibiliy to setup the device with new IOS file, which could be installed from usbflash1: e.g.
I cannot enter break sequence (CTRL+BREAK over Secure CRT).
Error code:
Upgrade ROMMON initialized
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
program load complete, entry point: 0x8000f000, size: 0xcb80
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Leo Laohoo
To get the ISR G1 to boot an IOS (from ROMmon) using USB flash, the ROMmon itself needs to be upgraded first.
Next, is there a compact flash currently in the slot?  If so, eject the CF and copy the IOS into the CF using a multi-card reader.
Leo Laohoo
Hi Leo,
i was not aware, that it is "so" easy to just copy the IOS file to the CF card.
This worked directly (more effort to find a card reader :) )
Thanks for your help! Appreciated!
Don't forget to mark this thread as "Answered" if everything is working.
