11-03-2016 03:51 AM - edited 03-11-2019 12:12 AM
Hi everyone,
We're using the APIC-EM in our environment and that involves ssh connections to all our devices every 30 minutes. The configuration related traps/events strains certain monitoring systems of ours, including Cisco ACS remote syslog servers.
Is it possible to filter the APIC-EM user from being stored under ACS View, and/or not to send these events to a remote syslog server?
Thanks!
Solved! Go to Solution.
11-03-2016 07:16 AM
Hi Nadav,
I do see such an option in ACS. However the opposite of what you want is available.
If you navigate to below "Menu", you would see that you can define "user" for which there ACSVIEW would not collect any logs and send it to
Monitoring Configuration > | System Configuration > | Collection Filters |
Kanwal
Note: Please mark answers if they are helpful.
11-03-2016 07:16 AM
Hi Nadav,
Kanwal
11-03-2016 09:22 AM
Sounds good, thanks. Is there any way to ensure that those specific syslogs don't get sent from the ACS to the remote syslog server?
11-03-2016 09:29 AM
