11-04-2016 08:12 AM - edited 03-12-2019 01:29 AM
having a problem regarding NOOP option, bellow message error, I want to allow nop action according to this discussion
%ASA-6-106012: Deny IP from x.x.x.x to y.y.y.y , IP options: "Noop"
https://supportforums.cisco.com/discussion/11646641/unfamiliar-asa-log-message
but, I dont find inspect ip-options under protocol inspection section (see attached)
policy-map type inspect ip-options Options-pmap
ERROR: % Invalid input detected at '^' marker.
How can I enable ip-options?
Thank you!
Solved! Go to Solution.
11-07-2016 03:24 PM
The command was introduced in 8.2(2). You would need to upgrade to get that command option.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/intro.html#wp1063588
"You can now control which IP packets with specific IP options should be allowed through the ASA. You can also clear IP options from an IP packet, and then allow it through the ASA. Previously, all IP options were denied by default, except for some special cases.
Note This inspection is enabled by default. The following command is added to the default global service policy: inspect
The following commands were introduced: policy-map type
Kanwal
Note: Please mark answers if they are helpful.
11-07-2016 12:32 PM
any idea?
thanks
11-07-2016 02:14 PM
Which version of ASA are you running?
configure mode commands/options:
diameter Configure a
h323 Configure a
ipv6 Configure a
lisp Configure a
radius-accounting Configure a
sip Configure a
skinny Configure a
Can you paste "show version" output from your
Kanwal
11-07-2016 03:20 PM
Thank you for your reply.
Asa version:
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.3(1)
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
Hardware: ASA5550, 4096 MB RAM, CPU Pentium 4 3000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 250
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
SSL VPN Peers : 2
Total VPN Peers : 5000
Shared License : Disabled
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Disabled
This platform has an ASA 5550 VPN Premium license.
Inspection type:
ASA(config)# policy-map type inspect ?
dcerpc Configure a policy-map of type DCERPC
dns Configure a policy-map of type DNS
esmtp Configure a policy-map of type ESMTP
ftp Configure a policy-map of type FTP
gtp Configure a policy-map of type GTP
h323 Configure a policy-map of type H.323
http Configure a policy-map of type HTTP
im Configure a policy-map of type IM
ipsec-pass-thru Configure a policy-map of type IPSEC-PASS-THRU
mgcp Configure a policy-map of type MGCP
netbios Configure a policy-map of type NETBIOS
radius-accounting Configure a policy-map of type Radius Accounting
rtsp Configure a policy-map of type RTSP
sip Configure a policy-map of type SIP
skinny Configure a policy-map of type Skinny
I think ip-options is supported, this is why I have the error message regarding NOOP, but I don't know how to enable this option and tune it!
Thanks.
11-07-2016 03:24 PM
Kanwal
11-07-2016 03:27 PM
Ok, it's clear.
Thank you very much!
11-07-2016 03:28 PM
I am glad
Kanwal
