11-07-2016 03:22 AM - edited 07-05-2021 06:05 AM
Hello Experts,
I have one SSID which having RADUIS authentication but when client try's to connect it ..it fails ...
here are the logs from thecontroller.
Dot1x_NW_MsgTask_0: Nov 07 13:05:08.371: %DOT1X-3-INVALID_WPA_KEY_MSG_STATE: [PA]1x_eapkey.c:1002 Received invalid EAPOL-key M2 msg in START state - invalid secure bit; KeyLen 40, Key type 1
*Dot1x_NW_MsgTask_0: Nov 07 13:04:56.767: %DOT1X-3-AAA_AUTH_SEND_FAIL: [PA]1x_aaa.c:849 Unable to send AAA message for client 90:2e:1c:47:e7:80
*Dot1x_NW_MsgTask_0: Nov 07 13:04:56.765: %DOT1X-3-ABORT_AUTH: [PA]1x_bauth_sm.c:450 Authentication Aborted for client 90:2e:1c:47:e7:80 Abort Reason:DOT1X RESTARTED DUE TO EAPOL-START/CLIENT ROAM
05-25-2017 10:15 PM
Hello experts,
kindly someone share the resolution for the same.
05-28-2017 10:59 PM
Which version you are running on WLC ?
Which WLC model you are using ?
How is your seup ?
Dont forget to rate helpful posts
05-28-2017 11:26 PM
8.2.151.0
5508
How is your seup ?
Radius Servers are in US and reachable via MPLS and S2S Tunnel also.
I have tried by changing the advanced eap bcast-key-interval to 86400 from default 3600 but issue is still there.
I also unchecked
Enable Session Timeout |
but this is also not worked ..
Now this is getting serious issue and 10+ users are already affected from this.
05-28-2017 11:35 PM
only few clients are having issues or its with all clients ?
paste the output of the command: sh wlan <id>
05-28-2017 11:51 PM
Please make sure shared key between WLC and RADIUS server is the same.
BR,
John
05-29-2017 12:15 AM
= Same only..
05-29-2017 01:51 AM
Got anything Sir...Anyone..
05-29-2017 02:02 AM
I think:
you must be hitting a bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu15866/?referring_site=bugquickviewredir
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw37942/?referring_site=bugquickviewredir
05-29-2017 02:20 AM
Unlikely..Users are getting disconnected and we need to manually re connect to the SSID this is non frequent in nature and random occurring issue..
05-30-2017 10:04 PM
Dear Sir,
Did not able to find the bug in the release notes 8.2.151.0 .
Can you please guide further . i have upgraded the drivers of the laptop to the latest Intel 19.60 release but issue still persists.
05-29-2017 12:14 AM
up to 20 Clients Not all.
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... GLOBALACCESSII
Network Name (SSID).............................. GLOBALACCESSII
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Disabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
ATF Policy....................................... 0
Number of Active Clients......................... 122
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ pune_main_office
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
--More-- or (q)uit
PMIPv6 MAG Profile........................... Unconfigured
PMIPv6 Default Realm......................... Unconfigured
PMIPv6 NAI Type.............................. Hexadecimal
PMIPv6 MAG location.......................... AP
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
--More-- or (q)uit
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ 151.171.47.224 1812 *
Authentication................................ 151.171.47.215 1812 *
Authentication................................ 10.106.3.59 1812 *
Accounting.................................... 151.171.47.224 1813 *
Accounting.................................... 151.171.47.215 1813 *
Accounting.................................... 10.106.3.59 1813 *
Interim Update............................. Enabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
--More-- or (q)uit
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
OSEN IE.................................... Disabled
Auth Key Management
802.1x.................................. Enabled
PSK..................................... Disabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
OSEN-1X................................. Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Disabled
GTK Randomization.......................... Disabled
--More-- or (q)uit
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Enabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
--More-- or (q)uit
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flex Avc Profile Name............................ None
Flow Monitor Name................................ None
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
--More-- or (q)uit
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Mobility Anchor List
WLAN ID IP Address Status Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority Policy Name
Lync State ...................................... Disabled
--More-- or (q)uit
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
12-15-2017 12:36 AM
Hello @pankaj.bandewar
Did you find a solution to your problem? As i am having the same issue affecting few users only.
04-13-2018 09:43 AM
Was there any resolution too this?
I am running the same 8.2.151.0 on 5508 and WPA2. I am getting the exact same symptom. It is very random. I am curious as to what might have been done.
Thank You!
05-22-2018 10:12 AM
Well I did something Like this
1.Upgrade the NIC Card software version on Laptops.
2.Change the default epol key interval time to 24 hrs.
3.disable the session timeout.
4.enable the NAC state as : RADIUS NAC
5. Upgrade the IOS of Controller to Cisco Recommended ver.
resolved finally..
