11-10-2016 08:50 PM - edited 03-11-2019 12:13 AM
Hi All,
I was trying to a config restore from a TFTP server, but it fails.
vic-acs01/admin# acs restore ACE-Config-160922-1542.tar.gpg repository Repository
Restore requires a restart of ACS services. Continue? (yes/no) yes
Initiating restore. Please wait...
% restore in progress: Starting Restore...10% completed
% restore in progress: Retrieving backup file from Repository...20% completed
gpg: decrypt_message failed: Unknown system error
tar: This does not look like a tar archive
tar: backup/appcomponent/db/acs.db: Not found in archive
tar: backup/appcomponent/db/acs*.log: Not found in archive
tar: Exiting with failure status due to previous errors
% restore in progress: Decrypting backup data...25% completed
% Error: Failed to perform ACS restore: The backup file decryption failed. Wrong encryption key or corrupted download from repository)
vic-acs01/admin# sh restore history
Thu Nov 10 20:06:16 PST 2016: restore ACE-Config-160922-1542.tar.gpg from repository Repository: error - acs script error
Thu Nov 10 20:19:37 PST 2016: restore ACE-Config-160922-1542.tar.gpg from repository Repository: error - acs script error
Thu Nov 10 20:28:36 PST 2016: restore ACE-Config-160922-1542.tar.gpg from repository Repository: error - decrypt failed
Thu Nov 10 20:30:11 PST 2016: restore ACE-Config-160922-1542.tar.gpg from repository Repository: error - decrypt failed
Thu Nov 10 20:34:00 PST 2016: restore ACE-Config-160922-1542.tar.gpg from repository Repository: error - decrypt failed
vic-acs01/admin#
vic-acs01/admin# sh run | b repo
url tftp://10.10.79.13/
vic-acs01/admin# sh repository Repository
% Protocol does not support listing directories
vic-acs01/admin#
CF
Solved! Go to Solution.
11-11-2016 05:17 PM
Hi CF,
Yes, you can add another repository.
Kanwal
Note: Please mark answers if they are helpful.
11-11-2016 08:13 AM
Hi CF,
Are you sure you are using the same key for decryption which you had used while taking the backup?
Also, show repo <repo name> will only list directories if the protocol type is FTP.
Kanwal
11-11-2016 10:51 AM
Hi Kanwal,
Its not giving me any option to enter any password. How should I enter the password?
CF
11-11-2016 11:24 AM
Hi CF,
Apologies. I didn't notice that you were not prompted for it. But
acs56/admin#
Please enter backup decryption password [8-32 chars]:
And
It would first retrieve the file and then try to decrypt it. And it seems even before it tries to decrypt, there is something which is causing it to error out.
I would suggest a different FTP server and if
Kanwal
11-11-2016 05:02 PM
Hi Kanwal,
I don't know if I can use a different TFTP/FTP server because the configuration of the repository is mapped to the IP address:10.10.79.13
Or can I just add one more Repository config in the running-config and try from that new TFTP config?
CF
11-11-2016 05:17 PM
Hi CF,
Kanwal
11-14-2016 01:14 PM
Thanks Kanwal!
I added another repository and copied the file to that TFTP server. And it worked!
CF
