11-14-2016 06:54 AM - edited 03-14-2019 04:46 PM
Hello everyone,
Does anyone in this prestigious forum know if there is any option in the CAD in which an agent cannot go to the Not Ready state, and that is only allowed that state with the password of the supervisor?
Martín.
Solved! Go to Solution.
11-14-2016 09:17 AM
I'm not sure that you can fully take away the ability to go into not ready
A
This will force ready using a timer action
https://supportforums.cisco.com/discussion/12509261/changing-agent-state-not-ready-ready-automatically-after-set-minutes
This will keep user in ready
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-contact-center-express/49703-agentunavail.html
So, with
You can then have someone pull reports checking agent state history for management and discipline accordingly.
11-14-2016 09:17 AM
A
So, with
11-14-2016 06:11 PM
Thank you very much for your response Sean.
The options you mentioned are valid and we already have them applied.
I need to apply more control measures over the agents.
I was hoping that Cisco would offer some such option of these kind.
Martín.
11-15-2016 07:36 AM
Yup, sorry
