Problems Deleting PNP Jobs In APIC-EM
Brett
I was testing how to configure stack switches using APIC-EM and when I went to go to delete the job it says "Delete failed: Device can be deleted only in PENDING/UNCLAIMED/PROVISIONED/ERROR states".  However, the job is in a "Pending" state.  Also, the other stack job I have been testing I can't delete that job because it is stuck in a "Cleaning Device" state.  I have waited for about 14 hours before trying to delete it again and still am coming up with the same errors.  Any suggestions on how to delete these jobs?  Thanks.
ngoldwat
Level 4
Level 4
Have you opened a TAC case on this?  What version of APIC-EM? Are you integrated with Prime Infrastructure? If you wish you can run reset_grapevine which will take you back to a default installation.
ngoldwat
Level 4
Level 4
Yup, I have opened a TAC case and am working with them on this issue.  My current version is 1.2.0.1594, and I have integrated Prime with it.  The job was created in APIC, not in Prime.
I had to run reset_grapevine clobber to remove those devices.
nathan.spena
I have this exact same issue, where the device is always stuck in the pending state. I delete the device and readd it and its still stuck... Wont allow me to reset it.
