Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929020members
1243000discussions
Community Activity
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 338 Views
  • 14 replies
cant wr or copy run start
hi all,before on this switch (nexus 7000) i could do a "wr" or "copy run start" no problem but now i get thiswr[########################################] 100%Configuration update aborted: request was abortedthanks,rob
C9500 Stackwise-virtual failover BGP downtime
Hello,we have deployed pair of 9500-32C in Stacwise-virtual. It is Aggregation node of big site and connecting to backbone by 2 EBGP links (one from each switch).I have noticed long downtime during ISSU and as we are deploying more of these to other ...
ms339r001 by Level 1
  • 66 Views
  • 2 replies
Forward traffic from subnet to another on C3750
hi guys thanks for your suggestions in advancehere is my lab setup sorry for the primitive drawing(TYPO in CT2 Bib1/0/12 it is actually 123.123.123.242/30)i modified ips to fake ones. 10.0.22.1/24 is one of our vlans that has full internet access.CT1...
gabecz by Level 1
  • 93 Views
  • 1 replies
新プラットフォーム移行後にSlidoを使うことができない
はじめにControl Hub でSlido を有効にするネットワークに関する制限を確認する設定を変更してもSlidoが有効にならないときは参考情報   はじめに 本記事ではWebexで新プラットフォームであるWebex Suite meeting platformへ移行後、Slido機能が利用できない場合に確認していただきたい設定箇所について解説します。 ※本ドキュメントは、2024年4時点の情報を元に作成しており、Webex Suite meeting platformへ移行済みかつ、Web...
Resolved! DNA Center and Meraki Dashboard
Hi,I'm trying to integrate the Meraki Dashboard in DNA Center (2.3.5), but I'm running into some issues.In the "Add Device" screen it asks for "API / Password" in the "HTTP(S)" section.If I input the API here, I can get the Organization details, but ...
mjrduarte by Level 1
  • 74 Views
  • 3 replies
SSM On-Prem TACACS+ login after upgrade not working
Hello,I upgraded our On-Prem server from Release 8-202201 to 8-202206. After the upgrade I'm not able to login to the GUI. We used TACACS+ (ISE) to authenticate. Also the local admin user is not working: "The requested user is not found".From the CLI...
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 97 Views
  • 6 replies
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 90 Views
  • 2 replies
VPN route-based unable to ping remote IP
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
Site-to-site vpn failover causing memory spike in spoke sites
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
PikaPika by Level 1
  • 97 Views
  • 5 replies
Cisco Secure Client CVE-2024-20337
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 265 Views
  • 9 replies
