Cloud Security
Cisco CyberSecurity
We are moving from Zscaler to Umbrella and use Canon Uniflow for the printers.The printers worked fine before Umbrella but can not print anymore since moving to Umbrella.There is only default policy enabled for the tunnels from sdwan routers to Umbre...
likvid by Level 1
  • 225 Views
  • 5 replies
What is best practice when it comes to AD connector(s)?If we were to have TWO AD connectors, is there a way to have it only fail over to the other connector if the active one went down? Rather than adding an additional connector on a separate server ...
bnuxoll by Level 1
  • 230 Views
  • 1 replies
Hi,Is there a way to get the username in the activity search of Umbrella for example when we have *not* an internal Active Directory but an Azure AD ? Assuming Virtual Appliances are only for Active Directory On Prem.Thank you.
Hello!Thanks for any help offered.Two of our clients are using Cisco Umbrella and when they access our web application they encounter an issue.(Our application is a standard JS app that makes requests to back-end APIs. Clients not using Cisco Umbrell...
billmacuk by Level 1
  • 782 Views
  • 3 replies
Has anyone else ever had someone's Cisco Secure Umbrella Client switch to filtering as the device local admin account instead of these user? Hre is what I have seen occur at least 3 times now.WE have a user who is in a policy that allows social media...
jmorton1 by Level 1
  • 199 Views
  • 0 replies
Hi all,Do i need to configure Saml authentication for authenticating user accessing internet via SIG proxy tunnel. If yes can i use cisco duo based on below article.https://docs.umbrella.com/umbrella-user-guide/docs/configure-duo-security-for-cisco-u...
sv7 by Level 3
  • 252 Views
  • 1 replies
Can anyone please let me know if there is any API available to add or delete role for the user . Currently from the following link there is no end point of such available https://developer.cisco.com/docs/cloud-security/#!list-roles   Thanks and Regar...
santhosh7 by Level 1
  • 342 Views
  • 1 replies
Top Solution Authors
