ā11-23-2016 08:44 AM - edited ā03-19-2019 11:51 AM
I have Expressway Edge VM. When it moved from a blade to a nother (vMotion) with the same Datastore, The server serial number changed and according to that the release key would be missed. Although according to the documentation, the vMotion is supported for Expressway deployment.
Thanks in advance
ā11-23-2016 10:17 AM
Yes, however, that's the expected behavior.
ā11-24-2016 12:49 PM
ā11-29-2016 05:04 AM
Hi Jaime,
I need your help. As per the documentation, The copy of the VM changes the serial number; We don't have this case.
Thanks in Advance
ā11-30-2016 03:12 AM
It seems that automatic High Availability based on vMotion policy is applied to all the VMs including the Expressway Edge VM not vMotion itself and as per the documentation, HA is not supported so we excluded the Expressway VM from this policy.
We tested manual vMotion (Migrate option) for the VM to a different host and the serial number of the VM didn't change.
Thanks Jaime for your help.
