Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1915054members
1215829discussions
Community Activity
+1(855)*956*5767 How to cancel or change a 𝐃𝐞𝐥𝐭𝐚?
+1(855)*956*5767 How to cancel or change a 퐃퐞퐥퐭퐚?+1(855)*956*5767 How to cancel or change a 퐃퐞퐥퐭퐚?+1(855)*956*5767 How to cancel or change a 퐃퐞퐥퐭퐚?+1(855)*956*5767 How to cancel or change a 퐃퐞퐥퐭퐚?+1(855)*956*5767 How to cancel or change a 퐃퐞퐥퐭퐚?+1(85...
Resolved! 4510+R ssh error after upgrade xe 3.11.07 to xe 3.11.09
Hi,after a upgrade from xe 3.11.07 to 3.11.09 we cannot open a ssh session to our 4510+R Switch. Before the upgrade everything works fine. The error message in the log  is:%SSH-3-BAD_PACK_LEN: Bad packet lenghthWe zeroised the  rsa key and generate i...
3802 AP LED turn off after registered with WLC
The LED light of 3802 AP is off after registered with 9800 WLC . But the 3802 access point is still working perfectly in providing the wireless connection to the end device .  We have factory-reset the AP and issue remain the same after the AP regist...
Jabber MRA DNS query for collab edge
Hi, We have a MRA deployment in our lab (simulating the internal and external env). We have got the Android, and CSF device working, connected to expressway edge. But our IOS devices are not working. Upon investigation we find out the Iphone/Jabber i...
access to enable mode via SSH without password ?
Hello,In our company we have two sites first we work on it and the second far from us 700 km usually I mange second site routers via SSH but recently we lost access so our engineer moved to the second site and remove all users & passwords from rom-mo...
WLC Guest Auth
Hello,What should we do if sometime the web auth for guest WLAN is not showing?
hs08 by Spotlight
  • 182 Views
  • 5 replies
Can't reach internet from neighboring routers
I am sure that I missing something simple in my understanding of how this works. I have connected my virtual CML lab to my network through the external connector. I am able to reach the internet from my edge router. However, for some reason I can not...
ryanbeaudry_0-1710777396519.png ryanbeaudry_1-1710777518233.png ryanbeaudry_2-1710777735675.png
[Q&A 集公開] 3/19 開催 NDFC (Nexus Dashboard Fabric Controller) 基本編
以下は 2024 年 3 月 19 日に開催した NDFC (Nexus Dashboard Fabric Controller) 基本編 の Q&A セッションでいただいた質問とその回答となります。多数のご質問誠にありがとうございました。なお、当日の資料や録画は以下より確認可能です。 プレゼンテーション資料  ウェビナー録画  イベント概要    質問 1. NDFC で Nexus スイッチの設定情報を取得する頻度はデフォルトの設定ではどのような周期となっておりますでしょうか。ご質問...
Eri Mizuno by Community Manager
  • 23 Views
  • 0 replies
请教3850交換机接口怎样引用PBR(策略路由)?
引用命令不知道是那里問題?g_core(config)#ip access-list extended hkbng_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0% Incomplete command.g_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0 anyg_core(config-ext-nacl)#exitg_core(config)#route-map hk...
D_W by Level 1
  • 110 Views
  • 5 replies
