Cisco Wireless Lan Controller PortChannel
Christian Maus
Hi all,
i'm trying to setup a ether-channel on WLC Controller 5008.
Till now, the Channel was not showing as connected (even after reboot).
Any idea about the issue?
Neighbor Switch:
Gi1/21    po3-wlan-ctrl  notconnect   1            full   1000 1000BaseSX
Gi1/22    po3-wlan-ctrl  notconnect   1            full   1000 1000BaseSX
Gi1/23    po3-wlan-ctrl  notconnect   1            full   1000 1000BaseSX
Gi1/24    po3-wlan-ctrl  notconnect   1            full   1000 1000BaseSX
interface GigabitEthernet1/21
 description po3-wlan-ctrl
 switchport trunk allowed vlan 6-8
 switchport mode trunk
 logging event link-status
 logging event trunk-status
 channel-group 3 mode on
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
(Wireless Lan Controller): LAG Mode on Next Reboot: Enabled
lan-core#show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.0(2)SG8, RELEASE SOFTWARE (fc2)
1.  Is there any messages of any type in the switch the port channel terminates on, particularly if you disconnect and reconnect the 4 fiber links?
2.  When the 4 fiber links are attached, could you do a "sh cdp neigh" to verify you actually have physical connectivity on the 4 ports?
3.  Do you see link lights on switch or controller that indicate the physical link is active?
Even if there is a mismatch on the LAG link somehow, I would think you should see a link light on the interfaces, but from the displays above it almost looks like interfaces are down.
10 Replies 10
Ric Beeching
Level 7
Level 7
Have you enabled all the interfaces on the WLC?
config port adminmode all enable
If so and still not working please post a show port summary
Ric
Please rate helpful / correct posts
Hi Ric,
config port adminmode all enable -> done
(Cisco Controller) >show port summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     1000BaseSX
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     1000BaseSX
7  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     1000BaseSX
8  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     1000BaseSX
Ok so the WLC can't even see an SFP in its physical slot. Is there definitely an appropriate SFP installed (GLC-T) with the UTP cable plugged in going to the 4500 switch?
Also I assume you have restarted the WLC at some point once you enabled LAG?
Ric
Hi Ric,
WLC was rebooted after LAG enabled.
I use 1000 BaseSX SFP with 50/125 fiber cable , i assume that it is not only working with GLC-T with UTP or am i wrong?
Just re-read up top and realised it could see the SFPs.. just in the last slots.. duh Ric.
So from a physical point of view you're plugging OM3 LC Fibre in on the last 3 ports but using copper on your first port.. bit odd but it will work if they are all the same speed (1 Gig).
Can you paste a show interface GigabitEthernet1/23 and show etherchannel 3 summary and show etherchannel 3 detail.
I take it you can't test a second link with GLC-T transceivers temporarily to see if it comes up?
Ric
Hi Ric,
yes first port will be replaced through the last 4 ports with OM3 LC
Havent tested yet with GLC-T transceivers as i dont have one on short notice...but yes i could test that as well.
Outputs:
lan-core-#show interfaces gigabitEthernet 1/23
GigabitEthernet1/23 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is 30e4.dbfd.1b0a (bia 30e4.dbfd.1b0a)
  Description: po3-wlan-ctrl
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 8 interface resets
     0 lost carrier, 0 no carrier
lan-core-#show etherchannel 3 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
3      Po3(SD)          -        Gi1/21(D)   Gi1/22(D)   Gi1/23(D)
                                 Gi1/24(D)
lan-core#show etherchannel 3 detail
Group state = L2
Ports: 4   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi1/21
Port state    = Down Not-in-Bndl
Channel group = 3           Mode = On              Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po3
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 62d:06h:17m:10s
Port: Gi1/22
Port: Gi1/23
Age of the port in the current state: 62d:06h:17m:14s
Port: Gi1/24
                Port-channels in the group:
Port-channel: Po3
Age of the Port-channel   = 21d:02h:51m:18s
Logical slot/port   = 11/3          Number of ports = 0
GC                  = 0x00000000
Port state          = Port-channel Ag-Not-Inuse
Protocol            =    -
Port security       = Disabled
Yes it definitely seems like some sort of mismatch of SFPs/Configs causing the link to not even come up.
Can you describe what the setup is on the wired side? Is it a dedicated line card hosting 1Gig links like the ethernet link that is already established?
Ric
Hi Ric,
the issue was very stupid one. Even though i changed both cable directions, there was an issue with the cable catch at the end of the cable. There was a minimal gap to the SFP input, so everything was configured properly, but the port channel didnt came up.
So everything is working now.... thx!
Did you already flip the individual RX/TX fibers on one side of the connection? The two fibers within the patchcord should be connected in a way that RX on one side is connected with TX on the other side.
Please rate useful posts... :-)
