11-28-2016 07:01 PM - edited 03-17-2019 08:48 AM
Hi All,
How do I determine the IP address used for TFTPD64 when IP address for router is 192.168.0.12 as I attempted to upload files into CUCM but after restarting TFTPD64 no files were uploaded into CUCM.
Using vmware to host cucm 7.0.1.
Server running vmware is 192.168.0.102
TFTPD shows 3 ip address ranges being 127.0.0.1 and 2 others being VMNET1 (IP address) and VMNET8 (IP address) (both virtual)
Using Bridged which users same subnet of host ip being 192.168.0.102. And as router IP is 192.168.0.12., I have made CUCM as TFTP. So that should be same IP address with appropriate option
Not using CUCM TFTP. Thought I would use TFTPD 64.
If anything needs clarifying.. please let me know..
Solved! Go to Solution.
11-28-2016 07:48 PM
Yes, that is right John, endpoints can request for config file from CUCM using HTTP \ TFTP to pull there configuration.
JB
11-29-2016 02:59 AM
If you have already added the endpoints to CUCM, you should be able to pull the config, check the link below.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200408-Retrieve-Phone-Configuration-File-from-T.html
JB
11-28-2016 07:13 PM
Hi John,
Are you looking to find what TFTP IP address is used by endpoints to pull config?
JB
11-28-2016 07:32 PM
Thanks Jitender for the quick response.
No. Trying to upload config files to CUCM using TFTPD.
11-28-2016 07:37 PM
Hi John,
that is not a recommended configuration. CUCM would generate config file when you add the phone to CUCM by Manual \ BAT \ Auto-registration options.
Why are you looking to do so.
JB
11-28-2016 07:43 PM
Thanks Jitender. So I presume it uses the config files in its database and configure settings in CUCM to upload into phone based on model number and DN..
11-28-2016 07:48 PM
JB
11-28-2016 08:17 PM
What in the case when CUCM not have config files in its database for certain model of phone please?
11-28-2016 08:20 PM
Sorry Jitender. I accidentally clicked Correct Answer before replying..
11-28-2016 08:53 PM
Was i able to address all your doubts, let me know if you have any specific questions.
JB
11-29-2016 02:46 AM
If MAC addresses are already entered into CUCM, I presume they would have to be deleted to assist in auto registration?
11-29-2016 02:59 AM
JB
11-29-2016 01:56 PM
Sorry. Copped a power blackout last night. Have to check tonight and reply.
01-17-2017 03:51 AM
Hi Jitendra,
Sorry for taking so long to get back to you. This is OK now.
01-17-2017 03:54 AM
Thanks for updating the post, John.
JB
01-17-2017 04:04 AM
No worries.
