Showing results forĀ
Search instead forĀ
Did you mean:Ā
WLC 5520
abdulkarim041
Level 2
Level 2
I have want to install active and standby Wireless controller by using Cisco WLC 5520.
Do I need to buy licences only for one controller ? or separate licences for both active and standby?
BR
Scott Fella
If you are doing active/standby with SSO or N+1, you only purchase license for one, which will be the primary.  If you will be doing an active/active, then you purchase license for both.
-Scott
-Scott
Thanks Scott,
Kindly let me know how I can order WLC in CCW? Should I order both simple 5520 controllers?
BR
We are using below as guest anchor controller.
Anchor Controller:
Model: AIR-5520
OS version : 8.2.166.0.
We have to move existing tunnels from foreign controller 4402 to anchor controller 5508 to new anchor controller 5520.
Would like to know the compatibility whether it will work or not.
i have already gone through the compatibility matrix and found it bit confusing.
Please help me on this.
Thank you.
Krishna.
