12-01-2016 01:58 AM - edited 07-05-2021 06:11 AM
looking for the AP3802i which can be configured as autonomous AP (flashing -w7- Image instead of -w8-. Is this still possible?
While reading data sheet, I've found the order-option "C" at the end of the product-number.
EG: AP3802-E-K9 and AP3802-E-K9C. This "C" means "configurable", but what is "configurable"? I didn't have found any explanation.
Thanks.
Solved! Go to Solution.
12-01-2016 05:58 AM
HI Frank,
Cisco 3802 AP don't support Autonomous/Standalone mode. It only support CAPWAP(WLC based)or Mobility express.
AP3802-E-K9- for this you need a controller to make it work.
AP3802-E-K9C - It comes or need a Mobility express image to work as WLC and AP simultaneously. Also you can connect other APs to it.these AP will support 3802 WLC: http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/mobility_express/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01.html
Dont forget to rate helpful posts
12-01-2016 05:58 AM
HI Frank,
12-01-2016 06:00 AM
perfect, thanks.
