Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929181members
1243305discussions
Community Activity
SIP Calls one way audio after MIN-SE Expires
We're running into an issue where our agents on a third party contact centre system are experiencing 1 way audio on an intermittent basis roughly around the 15 minutes mark.This is a CUCM v10 solution, connected to said 3rd party contact centre solut...
Call Handler Not Reachable From Outside Call
Hi Experts,I am sitting with an unique issue where my Auto Attendant works perfectly from inside the office, however it is not reachable from external calls.Connection ISP > SIP > CUBE > SIP > CUCMWhat I am seeing is as soon as I direct the call to C...
Max number of licenses available for Cisco ISE
I'm speaking of Essentials/Advantage/Premier. We use on-prem SSM.is there way to know how many licenses Cisco ISE gets from the binding to a virtual account on Cisco SSM?The only piece of information is the consumed ones, like knowing how many you ar...
SSM ON-Prem TACACS+ and Clearpass
Hi,I am trying to configure TACACS+ on our SSM On-Prem server so that I am able to login on the Webinterface with my AD user. The TACACS+ configuration is done in Clearpass. And the test in the configuration window on the SSM server was successful.Bu...
Counterdoc_0-1713516283437.png Counterdoc_1-1713516355075.png Counterdoc_2-1713516408976.png
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 98 Views
  • 3 replies
Resolved! Python script to deploy NAC commands
Hi All!I am currently deploying NAC in my organisation's switches and was wondering if there is a Python script to help ease this task.The commands are almost the same on all the ports, except for the dot1x/mab priority one when there's a device conn...
Zakitis by Level 1
  • 88 Views
  • 2 replies
Cisco ISE cannot join Windows Server Core.
My Windows Server Core having an internal address of 192.168.50.2, when natting it (NAT) it has an address of 192.168.99.36 (I'm installing Windows Server Core image on an EVE-NG VM and the EVE-NG VM is installed on ESXi).I have a Cisco ISE VM instal...
Jason2005 by Level 1
  • 3 Views
  • 0 replies
WLC9800 map two vlans on the same ssid
Hello, I have a WLC9800 with 9115 APs.For clients, I have a Vlan (100) mapped to an ssid. I want to add another vlan (102) mapped to the same ssid.I have added the vlan 102 (configuration, layer2, add vlan), i have created a vlan group and added both...
