3750/3850 - limit host access port from 1GB to 100mbps?
aamercado
Level 4
Level 4
I like to prevent users from randomly downloading large stuff off the internet. I am thinking just limit host access port from 1GB to 100mbps on my campus 3750 and 3850 stack access switches?
If so, any sample configs. Anyways, I have
policy-map 100Mbps
class class-default
bandwidth remaining percent 10
interface GigabitEthernet1/0/1
switchport access vlan 182
switchport mode access
service-policy output 100Mbps
If there is other alternatives or options, can you share your solutions that work?
Iulian Vaideanu
Level 4
Level 4
If they are RJ45 ports you could just try "speed 100"...
Joseph W. Doherty
Don't believe the 3750 series will support an egress service-policy.
If the 3850 does, and if it works like routers, your bandwidth statement will not limit throughput.  You would want to police, or perhaps shape (if supported), at 100 Mbps.  You might limit the policer, or shaper, to public IPs (i.e. not slowing internal LAN traffic).
I found 2 resource so just go down a bit for vlan-base QoS on this guide
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Network_Virtualization/PathIsol.html#wp81660
and
http://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/qos-policing/19645-policevsshape.html#policingvsshaping
ip access-list extended limit_100mbps
permit ip any any
class-map match-any limit_100mbps
match access-group name limit_100mbps
match vlan  182   ß----------------------------------This is my Data VLAN
policy-map limit_100mbps
description LIMIT DESKTOP DOWNLOADING FROM INTERNET
class limit_100mbps
  police 100000000 800000 conform-action transmit  exceed-action transmit
  set dscp default
interface GigabitEthernet1/0/2
service-policy output limit_100mbps
Now to test. I notice that I can't get this to work with voip auto qos but on a plain data vlan, the configs take. Just need to test. Any further comments will be appreciate on this. Thanks
