12-02-2016 07:08 AM - edited 03-01-2019 12:59 PM
I have problem with hyperflex hx dataplatform. First i installed a few times but the vcenter api did not registered correctly so i could not see hx datastore plugin on vcenter. Because of that i connected one of the controller and created datastore from there but this time i am getting the errors below . I stucked with these is there any ideas ?
root@SpringpathControllerJL3UY517DJ:~# stcli datastore mount --name DS1
Failed to mount the datastore on some or all hosts
EntityRef(type=6, id='f8f7dd17-6f0c-de49-a9b7-c368023f34f9', name='10.9.9.10'):
accessible: False
reasonInaccessible: Some(Mountpoint not found on host)
mounted: False
EntityRef(type=6, id='7b99f84f-5ef5-3941-8ae7-f8df4c1dfabf', name='10.9.9.11'):
accessible: False
mounted: False
EntityRef(type=6, id='97520443-7d14-af45-8aae-be5af0b8e279', name='10.9.9.12'):
accessible: False
mounted: False
08-23-2018 07:43 PM
Have you run stcli cluster reregister to new vcenter ?
08-24-2018 05:48 AM
Greetings.
Please check /var/log/scvmclient.log file for error messages 'unable to get cluster map' from a specific IP and it keeps printing this in a loop.
Did you have a previous hyperflex cluster instance installed before? There could be old references to the datastore names...
Run 'grep -i nas /etc/vmware/esx.conf' on each ESX node in the cluster, and check for something similar to below:
/nas/ESI-HX/enabled = "true"
/nas/ESI-HX/share = "192.168.1.10:ESI-HX"
/nas/ESI-HX/host = "123456789876654432-47738438636838"
You will want to check with TAC on steps how to clean up the old entries:
esxcfg-nas -d <ds-name>
left over entries in /etc/hosts file..
Kirk..
