NIM-8CE1T1-PRI reload by NGIO control packet loss detected on ISR4351
drissfadli
Hi All,
I have ISR4351, with card NIM-8CE1T1-PRI.
Pinging through the E1 link 0/1/7 (ser0/1/7:0) to next hop 1.1.1.2 make the module NIM-8CE1T1-PRI reloading???
See the steps of reproducing the problem.
Configuration below:
Tanks for your valuable help.
version 15.6
no platform punt-keepalive disable-kernel-core
hostname R4351
boot-start-marker
boot system bootflash:isr4300-universalk9.03.17.03.S.156-1.S3-std.SPA.bin
boot system bootflash:isr4300-universalk9.16.03.02.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
card type e1 0 1
card type e1 0 2
enable secret 5 $1$fUKp$98WodmT7cxxwIU8Qd9zDn/
no aaa new-model
subscriber templating
username cisco privilege 15 password 0 cisco
redundancy
 mode none
controller E1 0/1/0
controller E1 0/1/1
controller E1 0/1/2
controller E1 0/1/3
controller E1 0/1/4
controller E1 0/1/5
controller E1 0/1/6
controller E1 0/1/7
 framing no-crc4
 clock source line primary
 channel-group 0 timeslots 1-31
 logging-events detail
controller E1 0/2/0
controller E1 0/2/1
controller E1 0/2/2
controller E1 0/2/3
controller E1 0/2/4
controller E1 0/2/5
controller E1 0/2/6
controller E1 0/2/7
 framing no-crc4
 clock source line secondary
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface Serial0/1/7:0
 ip address 1.1.1.1 255.255.255.0
 encapsulation ppp
 load-interval 30
interface Serial0/2/7:0
 ip address 1.1.1.2 255.255.255.0
 encapsulation ppp
 load-interval 30
 vrf forwarding Mgmt-intf
 ip address 192.168.10.51 255.255.255.0
 negotiation auto
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http secure-server
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password cisco
 login
line vty 5 15
 password cisco
 login
network-clock revertive
network-clock synchronization automatic
network-clock input-source 250 controller E1 0/1/7
end
R4351#
R4351#ping 1.1.1.2 repeat 10000
Sending 10000, 100-byte ICMP Echos to 1.1.1.2, timeout is 2 seconds:
*Dec  4 22:18:51.290: %IOMD-3-MODULE_MESSAGE: SIP2: iomd:  NIM-8CE1T1-PRI[0/1] NGIO control packet loss detected: module reloading.....
*Dec  4 22:19:02.300: %SPA_OIR-3-RECOVERY_RELOAD: subslot 0/1: Attempting recovery by reloading SPA.
*Dec  4 22:19:02.303: %SPA_OIR-6-OFFLINECARD: SPA (NIM-8CE1T1-PRI) offline in subslot 0/1
*Dec  4 22:19:02.601: %NETCLK-6-SRC_UPD: Synchronization source E1 0/1/7 status (Signal Failure) is posted to all selection process....
*Dec  4 22:19:09.356: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/7:0, changed state to down
*Dec  4 22:19:09.356: %LINK-3-UPDOWN: Interface Serial0/1/7:0, changed state to down................
Success rate is 99 percent (4909/4941), round-trip min/avg/max = 3/3/29 ms
R4351#
R4351#
*Dec  4 22:20:07.467: %SPA_OIR-6-ONLINECARD: SPA (NIM-8CE1T1-PRI) online in subslot 0/1
*Dec  4 22:20:23.530: %CONTROLLER-5-UPDOWN: Controller E1 0/1/7, changed state to up
*Dec  4 22:20:25.531: %LINK-3-UPDOWN: Interface Serial0/1/7:0, changed state to up
*Dec  4 22:20:25.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/7:0, changed state to up
R4351#
drissfadli
additional information on the problem (sh ver + sh platform):
R4351#sh ver
Cisco IOS XE Software, Version 03.17.03.S - Standard Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.6(1)S3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 21-Nov-16 18:07 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
R4351 uptime is 3 hours, 16 minutes
Uptime for this control processor is 3 hours, 17 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.17.03.S.156-1.S3-std.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             None             None             None
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4351/K9 (2RU) processor with 1646117K/6147K bytes of memory.
Processor board ID FDO1952A0JG
3 Gigabit Ethernet interfaces
2 Serial interfaces
16 Channelized E1/PRI ports
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
R4351#sh plat
R4351#sh platform
Chassis type: ISR4351/K9
Slot      Type                State                 Insert time (ago)
0         ISR4351/K9          ok                    03:17:15
 0/0      ISR4351-3x1GE       ok                    03:16:13
 0/1      NIM-8CE1T1-PRI      ok                    00:05:06
 0/2      NIM-8MFT-T1/E1      ok                    03:14:36
1         ISR4351/K9          ok                    03:17:15
2         ISR4351/K9          ok                    03:17:15
R0        ISR4351/K9          ok, active            03:17:15
F0        ISR4351/K9          ok, active            03:17:15
P0        PWR-4450-AC         ok                    03:16:54
P2        ACS-4450-FANASSY    ok                    03:16:54
Slot      CPLD Version        Firmware Version
0         15030325            16.2(2r)
1         15030325            16.2(2r)
2         15030325            16.2(2r)
R0        15030325            16.2(2r)
F0        15030325            16.2(2r)
R4351#
