12-06-2016 03:03 PM - edited 03-12-2019 01:37 AM
Can we create multiple VRFs on ASA? If yes, then what would be the commands to do so?
12-06-2016 07:48 PM
The ASA does not support VRF but depending of the ASA you can use multiple context, you can take a look to the following documentation:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/ha_contexts.html
Hope this info helps!!
Rate if helps you!!
-JP-
12-07-2016 08:25 AM
Thanks JP
Actually we have a pair of ASA-5585 in failover group. They are currently operating in single mode. As per your guidance we need to change them to milti mode from single mode for multi context. These firewall pair is in production.
What would be the best approach or guidelines to put them in multi mode with minimum risk to the network and current traffic through them?
