12-07-2016 05:35 AM - edited 03-15-2019 06:25 AM
I would like to know if it's possible to concatenating the name of a global variable in an ICM script.
i've tried to do so, but it seems that the script is not recognizing it.
any input will be appreciated.
Thanks and regards.
12-07-2016 07:08 AM
12-07-2016 07:20 AM
Hello David,
it's my colleague who's trying to concatenate the name, so i don't have the ICM script at hand.
but the idea is instead of using an IF statement for a fixed globalvariable name for a contact center open check, we would like to have the variable name concatenated using other PVs.
we've tried to concatenate the name with and without "Global" at the beginning of the script. and in both cases the If statement goes through the x instead of the true path.
let me know your thoughts.
Thanks.
12-07-2016 07:57 AM
Sorry I'm still not 100% I understand, is this it? You have a global var named user.varname, you want to take a few PVs and create the string user.varname. If so, this is not possible.
david
12-07-2016 08:00 AM
yes that's it...and this is what i thought as well, that it's not possible..but i thought maybe there is a workaround for the inconvenience.
12-07-2016 11:40 AM
Yeah it sucks that it's not. We've tried this with SG and PQ in order to make scripting far more dynamic, but nope. Good luck.
david
