12-09-2016 10:14 PM
i want to reload the whole ASR9K chassis with eem script ( tcl ) , i did try below script but not reach my target yet.
::cisco::eem::event_register_syslog tag 1 pattern "TEST" occurs 1 maxrun 1200
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
action_syslog priority warning msg "EEM Triggered"
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $result
if [catch {cli_exec $cli1(fd) "admin"} result] {
if [catch {cli_write $cli1(fd) "reload location all"} result] {
if [catch {cli_read_pattern $cli1(fd) "Proceed with reload"} result] {
if [catch {cli_write $cli1(fd) "\n"} result] {
if [catch {cli_close $cli1(fd) $cli1(tty_id)} result] {
Once above script was triggered all the LCs and standby RSP was reload, but not the active RSP
RP/0/RSP0/CPU0:PE3#show platform
Fri Dec 9 22:57:30.284 UTC
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-SE(Standby) IOS XR RUN PWR,NSHUT,MON
0/1/CPU0 A9K-2T20GE-E IOS XR RUN PWR,NSHUT,MON
0/2/CPU0 A9K-MOD80-TR IOS XR RUN PWR,NSHUT,MON
0/2/1 A9K-MPA-4X10GE OK PWR,NSHUT,MON
RP/0/RSP0/CPU0:PE3#
RP/0/RSP0/CPU0:PE3#
RP/0/RSP0/CPU0:PE3#
RP/0/RSP0/CPU0:PE3#logmsg TEST
Fri Dec 9 22:57:38.199 UTC
RP/0/RSP0/CPU0:PE3#RP/0/RSP0/CPU0:Dec 9 22:57:39.300 : tclsh[65865]: %HA-HA_EEM-4-ACTION_SYSLOG_LOG_WARNING : test.tcl: eem Triggered
Fri Dec 9 22:57:51.463 UTC
0/RSP1/CPU0 A9K-RSP440-SE(Standby) BRINGDOWN PWR,NSHUT,MON
0/1/CPU0 A9K-2T20GE-E BRINGDOWN PWR,NSHUT,MON
0/2/CPU0 A9K-MOD80-TR BRINGDOWN PWR,NSHUT,MON
i also try action_reload ( eem tcl command extension ) but the result is, it reload only the active RSP.
Please suggest, how to reload the whole chassis ?
12-11-2016 10:03 AM
How would you reload the chassis manually? EEM doesn't have any magic capabilities. If there is a CLI command to do it (and this reload location all sounds right), then if EEM executes it, the chassis should reload. If that is not working for some reason, it sounds like you could do the CLI process, then call action_reload.
12-11-2016 08:05 PM
Thanks Joe,
the way we reload the chassis manually is " admin --> reload location all "
For the eem script to reload the chassis i got this work.
} else {
action_reload
12-12-2016 10:18 AM
Okay, so it seems like you found the solution? Not sure if you're still asking a question in this post.
