Unable to upgrade A9K-RSP-8G on ASR9006 to IOS-XR 6.1.2
Ahmed Muhi
Hello All,
I am trying to upgrade an ASR 9006 with RSP "A9K-RSP-8G" to IOS-XR 6.1.2 32 Bit, according to 6.1.2 release note RSP-2 are supported, as per the document:
PX PIE image files are the only option on all ASR9000 platforms including RSP-2 and ASR9001 starting from Cisco IOS XR Software Release 4.3.0.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/general/release/notes/b-release-note-asr9k-612.html
I am trying to upgrade from IOS-XR 6.0.2 to 6.1.2, this is a Lab ASR and for the 6.0.2 I used turboboot, so nothing is there.
After adding this PIE "asr9k-mini-px.pie-6.1.2" and activating it, the ASR rebooted though it got stuck and gave me this message:
set_chassis_type: chassis_type=0xef02fb found=TRUE
ASR9K (8641D PPC) platform with 8192 Mb of main memory
program load complete, entry point: 0x100000, size: 0x2ac20
MBI Candidate = disk0:asr9k-os-mbi-6.1.2/0x100000/mbiasr9k-rp.vm
MBI Candidate = disk0:asr9k-os-mbi-6.0.2/0x100000/mbiasr9k-rp.vm
CARD_SLOT_NUMBER: 1
CPU_INSTANCE: 1
MBI Validation starts ...
Mgt LAN 0 interface is selected
tsec_init_hw: configuring FE (port 2) for: Auto Speed, Auto Duplex
tsec_init_interface: hardware initialization completed
Interface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
No MBI confirmation received from dSC
AUTOBOOT: Boot string = disk0:asr9k-os-mbi-6.1.2/0x100000/mbiasr9k-rp.vm,1;disk0:asr9k-os-mbi-6.0.2/0x100000/mbiasr9k-rp.vm,2;
AUTOBOOT: autobootstate=0, autobootcount=0, cmd=boot disk0:asr9k-os-mbi-6.1.2/0x100000/mbiasr9k-rp.vm
MBI size from header = 21893592,Bootflash resident MBI filesize = 21893592
program load complete, entry point: 0x204184, size: 0x14e02d8
Attempting to start second CPU
Config = SMP, Running = SMP
Board type: 0x00100304
Card Capability = 0xffffffff
BSP: Board type : RO-RSP2
Processor family/kernel mismatch (2/4)
Crash[0,0] at init_cpu line 220.
From what I can guess the RSP A9K-RSP-8G is not compatible with IOS-XR 6.1.2.
I have also attempted using the turboboot VM of 6.1.2 still with no luck, also we have Cisco Software Manger CSM v3.3, though unfortunately for the ASR9K it only supports up to 6.0.2, unlike the CRS platform where it supports to 6.1.2.
I am just trying to know if there is any way to install 6.1.2 on the A9K-RSP-8G.
Thank you so much for your help and support.
Kind Regards,
Ahmed Muhi
2 Accepted Solutions
Eddie Chami
Ahmed
A9K-RSP8G and A9K-RSP4G have reached end of software development support, the last release that supports this hardware is 5.3.4. This hardware is NOT supported from 6.x onwards.
regards
Eddie.
Dinesh Pullat
4G and 8G are not supported from 61x onwards.
12 Replies 12
Eddie Chami
Ahmed
regards
Eddie.
Hello Eddie,
Thank you so much for your prompt response that was really helpful.
Hi Eddie,
Do you know if 6.1.2 will work with A9K-RSP440-TR or A9K-RSP440-LT?
Thank you in advance.
Yes it will.
Awesome, thanks Eddie!
That said, you should try 6.1.3 or wait for super EMR 6.1.4 out last week of May, first week of June.
Will do Eddie.  I ran into the same problem when I upgraded my A9K-RSP-4G from 5.3.4 to 6.1.2.  The upgrade was completed but crashed when system is booted.  I had to rollback to 5.3.4 to bring it back to normal.
Sorry to hear about the pain. A9K-RSP-4G does not support 6.1x, its last supported release was 5.3.4. Its done well for its age.. 5.3.4 is going to be around for a while. if you need to get to 6.1.x, you will need the RSP440s or RSP880s..
Yes, I found out about it the hard way and it wasn't that hard to rollback.  Thank you.
Dinesh Pullat
Hello Dinesh,
Thank you so much for your kind reply.
