12-12-2016 12:54 PM
I am looking for a single mode SC connected SFP+ transceiver that will go into my
Cisco C3KX-NM-1G SFP+ Module. What would you suggest for a SFP+ transceiver? Any suggestion?
Solved! Go to Solution.
12-12-2016 07:20 PM
The GLC-LH-SMD would be the most common choice. The complete list of coamptible transceivers can be found here:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc462044419
The detailed description of each transceiver's capabilities is here:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
At the transceiver end it is an LC type connector, as is the case for all SFP+ form factor transceivers. You simply use an LC-SC duplex single mode jumper cable if you have SC type patch panel.
12-13-2016 08:07 AM
Using 1000Base-EX transceivers over relatively short distances is generally not recommended unless you take care to insert optical attenuators to avoid over-driving the receiving ends.
Within a building or between nearby buildings we would not normally expect fiber attenuation greater than a couple of dB. The EX transceiver transmit range specification is +3 to -1 dBm. The receiver is designed for signal between +1 to -22 dBm.
Also, the EX transceiver cost is about twice that of the LH type.
12-12-2016 07:20 PM
12-13-2016 06:02 AM
Marvin,
Thanks for the quick reply.
My campus only has Single mode fiber. although GLC-LH-SMD can do both single mode and multimode, i don't see the use of the multi-mode for my design.
After looking at the link you sent I would like to see what you think of using GLC-EX-SMD. It only supports multimode.
The only drawback i see on the GLC-EX-SMD is that the distance between devices is less than 40km. That may affect the transceiver if it hit by a lot of power at a short distance.
Let me know what you think
12-13-2016 08:07 AM
12-13-2016 10:51 AM
Marvin,
I appreciate your answers.
I will proceed with the LH transceiver.
