ā12-20-2016 06:50 AM - edited ā07-05-2021 06:15 AM
in our project there 98 APs are registered in wlc 5760 i need to assign Static IP for Each APS.
is there command line method to assign Static IP for 2602 APS
Solved! Go to Solution.
ā12-20-2016 10:29 AM
Why do you need to assign static IP for
ā12-21-2016 12:25 AM
Since it is not a recommended practice to give static IP,
Anyway if you want to make it static you can use below CLI command
5760#ap name <ap_name> static-ip ip-address <ap_ip_address> netmask <netmask_value> gateway <gateway_ip>
Below is an example.
5760#ap name AP01 static-ip ip-address 192.168.100.1 netmask 255.255.255.0 gateway 192.168.100.254
If you know all the
Rasika
*** Pls rate all useful responses ***
ā12-20-2016 09:50 PM
Thanks Rasika,
it requirement to assign static IPS in our Project we have already apply for wism controller APS
If you know all the
Rasika
