12-21-2016 08:34 AM - edited 07-05-2021 06:15 AM
So, I have a wireless network setup with a Cisco 4400 WLC. I have several WLAN's both voice and data set up and broadcasting across all of our AP's connected to the network. I have a specific instance where, I have a new Wlan that I would like to only be available from 2 specific AP's, yet those AP's need to still have the other Wlans available on them as well. Looking for config suggestions..
Jason
Solved! Go to Solution.
12-21-2016 10:45 AM
You can do this by simply creating AP group & adding those two APs onto that group with required WLAN to advertise.
Rasika
*** Pls rate all useful responses ***
12-21-2016 10:45 AM
Rasika
12-21-2016 12:28 PM
Yea, so I think I figured it out. Currently, we only have the "default-APGroup". It looks like I will have to create two new Groups, and have one group have all the current wlans in it, and all the AP's not needed for the new wlan. Then create another group, that has all the wlans, plus the new wlan in it, and add the two ap's I want that new one to only show up on to that group.. Got it all ready to go, but will have to wait until after hours to drop the AP's to move them to the new groups..
12-21-2016 12:34 PM
Yes, you got it right :)
If everything worked as expected, you can mark the thread as "answered"
Rasika
