ASA 5510 blacklist not working.
Answered Question
Dec 21st, 2016
I have a ASA 5510. I'm trying to set up a blacklist. I have added this for the inbound access-list (access-group outbound in interface inside), but it is not working. Any ideas?
object-group network BLACKLIST
 network-object host xx.xx.xx.xx
access-list inside extended deny ip object-group BLACKLIST any
Correct Answer by GRANT3779 about 7 months 4 weeks ago
From what you have said, your access group statement seems to be referencing an ACL called outbound, but your ACL is called inside.
Overall Rating: 5 (1 ratings)
Correct Answer
GRANT3779 Wed, 12/21/2016 - 11:22
  • Bronze, 100 points or more
llangrell Wed, 12/21/2016 - 13:28
Thanks for the reply. I didn't do the configuration, and the naming is horrible. And my CLI skills are a little rusty. I changed the ACL, and it seems to be working. Thanks for taking a look.
GRANT3779 Thu, 12/22/2016 - 00:53
Glad it is working for you now.
When something needs to be named, whether it is an ACL, Route Map, Class Map etc.. I tend to always reference an abbreviation in my name, e.g RM for route-map, CM for class-map
ip access-list extended ACL_DF
route-map RM_DF permit 10
match ip address ACL_DF
I think a lot of others will most likely follow the same, or similar.
