Root for P2MP MLDP in-band signaling
Vadim Semenov
Hi, all,
i'm trying to configure P2MP MLDP LSP with in-band signaling and i'm using that guide for configuration. Configuration doesn't include root configuration
Network's scheme CE1 - PE1 - RR3 - PE2 - CE2
CE1 - mcast receiver
CE2 - mcast source
vrf definition one
rd 1:1
address-family ipv4
  route-target export 1:1
  route-target import 1:1
exit-address-family
ip multicast-routing vrf one
ip multicast vrf one mpls mldp
ip pim vrf one mpls source Loopback
CE1 generate IGMP version 3 SSM Report and i don't see any P2MP LSPs in mpls mldp database
PE1#sh mpls mldp database
* For interface indicates MLDP recursive forwarding is enabled
* For RPF-ID indicates wildcard value
> Indicates it is a Primary MLDP MDT Branch
From my understanding if PE1 receives SSM IGMP Report or PIM join - PE tries to find source root in static configuration ( this configuration doesn't exist in my case ) and in the second step PE1 tries to find next-hop through BGP/IGP protocol. PE1 has information about CE2 netotwork through BGP, but in my network PE1 doesn't generate MLDP lable mapping to the PE2.
  1. Could you please say what of reasons of that behaviour?
  2. Is it needed to configure RP-address on CEs, PEs if you use P2MP in-band signaling?
Adam Vitkovsky
Level 3
Level 3
Hi Vadim,
Looks like you are missing quite a lot
Check out this guide please:
http://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-2/multicast/configuration/guide/b_mcast_cg42crs/b_mcast_cg42crs_chapter_00.html#reference_A6A46F1BC21B4F5784E8528F2EA1E857
adam
netconsultings.com
::carrier-class solutions for the telecommunications industry::
adam
