Warning message
Cisco ASA5505 licensed host limit was exceeded
Hello Sir,
I am receiving syslog message - licensed host limit was exceeded.
Deny traffic for protocol 6 src outside:69.162.124.231/7086 dst inside:out-252/80, licensed host limit of 10 exceeded.
What does it mean?
Please help us to understand this issue.
Do we need to buy extra license for the same?
Praveen Kumar
mvsheik123 Sat, 12/24/2016 - 20:05
  • Gold, 750 points or more
Hi Praveen,
Correct. Based on the message, you seem to have ASA with 10 user license and ran out of that license due to 10 local hosts (inside work stations). 'Show Version' command will tell you what license you have. You can check the hosts by using 'Show local-host' command. You may need to purchase additional license based on your requirements. Here is the link for available license options for ASA units.Check Table A-1.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa72/configuration/gu...
hth
MS
mvsheik123 Wed, 12/28/2016 - 15:59
This message relates to how many users/workstations accessing Internet through ASA (from your LAN). The commands I gave you give you which hosts accessing and what license you have. The link I gave you helps you in planning what license you need so that additional users will not get this message.
hth
MS
Hello MS,
Thanks for the reply. But I am still confuse about inside host license error in firewall. We
have currently 10 host license for inside host in Cisco asa5505 firewall.
Your mean is that how many user is accessing cisco asa firewall from ASDM in lan that's why we getting 10 host limit exceed error.
                                               or
how many servers have internet access in VM so we are getting 10 host license exceed error
Would you please explain in more detail?
Let me introduce about my setup scenario
1 ) We have 3 servers (Vmware ESXi server)
2) We have more than 20 server on all 3 physical server.
Please help me to resolve this issue.
Thanks in advance.
Praveen Kumar
Saji Thomas Thu, 12/29/2016 - 20:42
Hi Praveen, server or desktops... it does not matter. With the basic license you can have only 10 devices behind the firewall in your private lan. The link MS provided says the same thing.
Thanks!
Saji
Saji Thomas Sun, 01/01/2017 - 23:27
Hi Praveen,
Depending on your requirements and the budget, contact the local Cisco sales for the pricing on the licenses.
http://www.cisco.com/c/en_in/about/contacts.html
Once you have the activation key, it is a peice of cake. I see your attachement and it looks like you are using ASDM. Use the following command on the CLI for activating the new key.
1) ASA#show activation-key <To see the present activation key>
2) ASA#conf t
3) ASA(config)#activation-key ******** <whatever key you got>
The ASA will show you the difference between the present running key and the new key you have entered. It will ask to reload for new features to take effect. Once you have the time prepared for the reload, reload the ASA.
4) ASA(config)#exit
5) ASA#reload <confirm with..yes>
6) ASA#show activation-key <To see the new activation key after the reload>
Thanks!
Saji
