12-22-2016 05:21 AM - edited 03-19-2019 11:57 AM
Is it possible to clear/drop/remove one person that is logged to CUCM via Expressway?
How to list the current session and remove the user that I need to drop from the current session
Antra
12-22-2016 07:07 AM
No, I don't believe there's a way to drop a user who is logged in via MRA, you can see the active sessions in the EXP-C
12-22-2016 11:56 AM
Hello Jaime,
Good day,
I am trying to set up mobile and remote access through Cisco expressway series. I have installed and licensed the expressway series. I have set up the unified communications traversal zone. I have installed the server certificates. My confusion is in expressway E. How do I register expressway E to Internet. I have dual network card. I have nat device (Cisco router) with only one public ip address. If I set up private ip on lan 1 and another private ip on lan 2 which well be statically mapped to the public ip, would it be a viable solution?
In addition, I do not have dns running in my network. Am only using the ip address. I do not know where to set up _collabedge
Hope to read from you
01-11-2017 12:50 AM
I suggest you to follow the document in the link below about deploying Expressway.
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=82734&tclass=popup
