Hi guys,i'm using the latest version of packet tracer (8.0.1) but still getting this problem and i really need the fileif anyone knows how to open it please help !!
The content you are looking for has been archived. View related content below.
Hi guys,Does anyone have a solid method of calculating supernetting without usng binary conversion?Although I have no problems with binary, I am sure there is a quicker way ;-))ThanksMarc
Please see attached pic. In this question, the destination address 10.0.1.15 matches the route in the routing table. But it's the broadcast address within that range. Would the packet still be routed with that route?what would the next hop be? 192.16...
Hi,We are in transition period migrating from one internal PKI to a new Internal PKI. Existing flexvpns are setup with certificate from the old PKI CA for IKEv2 tunnel protocol. We're bringing online a new flexvpn that has the certificate issued by...
Do ACI have self healing network?if using campus network and Cisco DNA , can it have self healing network? if so, does it mean only need replace hardware and fault cable in future?Meraki has self healing network, does it mean that massive Meraki can ...
Hi all,I have a CI I I I router with version 17.09.04a, and need to migrate the configuration from 1941. When I input scheduler allocate, it show "unrecognized command", is it not supported or somethings I missed ?Thanks.
Is there a way on a layer 3 device with multiple IP addresses on it to determine what the logging source-interface is set to? I need to go through and verify settings. Besides just going and running the command on everything I was hoping there was a ...
Please can a member make some time guide/help.I have a range of Cisco products set up and working on my SOHO; I purchased two additional APs and part way through configuration the CLI session would not start.PuTTY window opens, black background stati...
I hope I'm in the right spot......We have a number of Cisco switches and routers from older 2950 switches and 4400 routers to our newest 9300 switch. We have the console port connected to console management switches via RJ45 to serial cables. The con...
If you run that command, would future cleartext passwords also be encrypted?
Hello,I have a problem that's really bothering: I have a Cisco WS-C3850 L3 switch and I want to use it (partly) as a router: The network:I can ping from 10.9.0.3 to 10.9.0.1 and vice-versa.The problem I'm facing: when trying to ping from the firewall...
I have Cisco SG550XG switch-Switch network overview - I have assigned IP address of the switch as 192.168.64.21 and have created a VLAN for some ports IP 192.168.65.21. Now currently I have 64 and 65 subnet to use, but the issue is How to allow routi...
What does this command do? I searched the other forums and found just one reply to a similar request. It was very general and of not much use. I also searched Cisco's web site for this and found no real info. Can anyone tell me if this can be used fo...
Dear Team, We are having POE Pds and the Team is looking to connect the POE PD devices in Ring topology. 1. Is the POE PSE ports are one to once connection or possible to connect multiple PDs into one PSE2. Please suggest POE PSE support Ring topolog...
hI, I want to sell a new memory and disk from another/new partner. i can use the contract support for memory and disk since blade from original partner
Subject | Author | Posted |
02-20-2024 07:45 AM | ||
02-15-2024 09:08 AM | ||
02-14-2024 04:00 AM | ||
11-10-2023 09:28 AM | ||
11-09-2023 09:30 AM |
