I'm having an issue with calls coming into our environment sending a loud and long incoming call beep to the handset. This is not something that occurs when the call is coming internally. Is there something obvious that I am missing that I could check?
SPA endpoints are supported in the SMB community, might want to move it over there.
java
if this helps, please rate
