Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929276members
1243525discussions
Community Activity
Ongoing Event: Capture the Flag, get the Badge!
You asked, we heard you! Introducing the ThousandEyes Support Community Capture the Flag event from April 23rd at 8 AM PST to April 29th at 5 PM PST. This month the ThousandEyes Community is offering two Capture the Flag missions in a single upcoming...
CUCM 11.5.1 SU2 upgrade
Hello Everyone, one of my clients currently have a CUCM cluster with 1 publisher and 6 subscribers, this cluster is running version 11.5.1 SU2. i am planning a refresh upgrade to version 14 using PCD. but before this upgrade, i am planning a minor up...
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Connecting with +1-888-408-4362 QB Online Support
Connecting with +1-888-408-4362 QB Online Support: If the built-in resources don't quite hit the mark, it's time to connect with the Quick-Book Online support team. Here are your options:Live Chat: For quick queries, the live chat feature is a great ...
Resolved! Multiple Diffie Helfman Group In Phase 2 Cisco FMC-FTD
Hello, Is it possible on Cisco FTD managed by Cisco FMC define multiple DH Group in Phase2 ? From what i see it is just possible one. I tried put , but it doesnt accept. Also looking maybe for option to add thorugh flex config but didnt find any rel...
qsscisco by Level 1
  • 250 Views
  • 6 replies
Resolved! Segment routing dynamic option
Hello Everyone, I am new to segment routing. I am trying to learn the dynamic option of segment routing traffic engineering. I have 2 directly connected routers.R1---R2R1's Gi0/0/0/1 IP address 100.10.20.1R2'2 Gi0/0/0/1 IP address 100.10.20.21.1.1.1 ...
AAEP Maximum Domains
Hi All,I'm currently designing an ACI solution for a single customer that wants to use multiple tenants for different business functions (prod, dmz, dev etc) whilst using the same physical infrastructure. For ACI, I typically configure separate VLAN ...
Equivalent Command for 9800
A simple question....If I just knew where to find the answer:Doing MAC authentication on an 5520 WLC, I can see the MAC addresses accepted by the WLC if I issue the command:"sho macfilter summary"Can anyone tell me the equivalent command on a 9800 (y...
roo54 by Level 1
  • 64 Views
  • 3 replies
AP2702i degrading throughput
Hi community!I posted about some 2702i in autonomous mode, degrading throughput after some time - see post: Autonomous Mode Failing on Aironet 2702i-z-k9 - Cisco CommunityLast days I got a WLC 2504 and other 2702i access points  (in controlled - LWAP...
Extended ACL inbound and outbound
Good morning friends,I have created two extended ACLs for in and out of my int vlan and applied it under int vlan for both directions inbound and outbound. I have created ACLs entries like this.For int vlan no. Out1 permit ip 10.1.0.0 0.0.255.255 hos...
VLSM with Inter-VLAN routing
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
