After configuring NTP, Not synched???....
Soon Kwan Kwon
Hello all,
I've configured a lot of APs.
Below design is each of it.
a
There are dozens of network design like upper.
Among them, one controller does not synchronize NTP in a design.
I really don't know why it was not operated properly.
> Controller can ping with Internet SW <-- Internet SW has NTP server.
> Also Internet SW can ping Controller....
Although ping ok, why didn't synchronize NTP server....??
Please see the upper captured picture....
How to fix it...?ㅠ_ㅠ
SK.
10 Replies 10
Leo Laohoo
If the switch is Cisco, post the complete output to the command "sh ntp a".
Hello Leo,
This is output "sh ntp a" in Controller.
SW#show ntp associations
address ref clock st when poll reach delay offset disp
~203.248.240.140 .INIT. 16 - 1024 0 0.000 0.000 15937.
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
SW#
Please see the output...!
Thank you.
The WLC is behaving correctly.  Notice at the left-hand side there is only the "~".  If the NTP is synchronized to a valid time source the left-hand column should start with a "*".
So this means that the switch, where the WLC is attempting to synchronize the time source, is NOT in synchronize with a valid time source.  The WLC is, most likely, have detected that the time from the switch is invalid.
Hmmm...
Maybe do you know why the WLC is getting invalid time.. even though the SW has correct NTP server IP...
Is it possible device fault?
SW2#show ntp a
*~203.248.240.140 204.123.2.5 2 495 1024 377 7.014 -5.883 0.157
It is another sw I have... but it's working properly...
(Its sw is another network design's)
SK.
Could be a FW rule?
There aren't FW rule.
Hold on ... I saw an event once when the switch, a 6807-X, would keep loosing sync with a known NTP time source.  The cause of the issue was an IOS bug.
AH? Leo, where is the switch, 6807-X ?
Why did you judge the cause of the issue was IOS bug ?...
Leo,,
Like you said, IOS bug is correct.
Should I update IOS version...?!
Why did you say "Could be a FW rule?"
Actually I don't understand clearly...Leo
