Hi Mr. ivanchakarov
Really hope you ok and thank you very much indeed for your kind support. i really appreciate it alot.
Sorry for taking so long to reply, we got such big time different and besides that, i was working some in the village where theres no internet access. well, its africa and thats how it goes down here sometimes.
Well, what im trying to say is that , after doing the step 2, i was stacked on Step 3 where it askes me to Click Email Notification Tab. even according to the file i have attached, i do not see the Email Notification Tab, where Prime Infrastructure will have to displays the first Email Notification Settings page. thats the problem im talking about.
the only tab i see there are; Alarms, Events and Syslogs. so i dont see where to Click Email Notification tab, so i can go to Step 4; Alarm Category column.
So hope you understand me. by the way, i have pasted the steps covering this configuration on; Configuring Email Notifications for SNMP Traps.
So far, i have already configured the; Email Server Settings
Step 1 Log in to Prime Infrastructure.
Step 2 Select Monitor > Monitoring Tools > Alarms and Events.
Step 3 Click Email Notification tab. Prime Infrastructure displays the first Email Notification Settings page.
Step 4 In the Alarm Category column, click on the System category's name. Prime Infrastructure displays a
second Email Notification Settings page.
Step 5 Under Send email for the following severity levels, select all of the severity levels for which you want
Prime Infrastructure to send email notifications.
Step 6 In To, enter the email address to which you want Prime Infrastructure to send email notifications. If you
have multiple email addresses, enter them as a comma-separated list.
Step 7 Click Save. Prime Infrastructure displays the first Email Notification Settings page.
Step 8 In the Enable column, make sure System is selected, then click Save.
Hope you got it sir.
