01-06-2017 03:12 PM - edited 03-15-2019 05:37 AM
Have a warning on my VG248. says: "Warning: SCCP 20: Registration Failed: Security Error.
i know disabling the ports will make them go away. Question is, is it okay to leave ports enabled while its spitting out these errors?
Solved! Go to Solution.
01-07-2017 09:06 PM
Attachment shows you have an issue with registration on SRST server not as you indicated "security Error". anyway, the error message stated you have configured an SRST provider, but the device does not appear to be responding as an SRST server. If you are relying on SRST and see this warning, the VG248 might have difficulty using SRST services if connectivity to Cisco CallManager is lost. Check the configuration and status of the SRST device.
use the link below also for more help...
01-07-2017 09:06 PM
