Cisco Firepower API
jason_williams
Firepower Management Center API - Object Management
 One of my customers, recently migrated to Cisco Firepower Threat Defense. One of the challenges that I ran into was the ASA Configuration migration script from Cisco duplicated objects in Firepower Management Center.
 To delete these objects, required clicking delete for each object. This was a painful and time consuming activity, so I built a python script to delete object utilizing the FMC API. Attached to this blog is a python script that will allow you to delete unused objects. If you need to delete a large number of objects, it will save you time.
jason_williams
I created a new python script that will utilize the API to create a CSV of the Access Control Policy. See the link below for all the  FMC Python scripts.
https://github.com/scourge71/fmcapi
9 Replies 9
jason_williams
Jason,
Nice scripts. Do you have similar on creating or adding a new access rule to an existing access control policy? Getting the following on my attempt:
{"error":{"category":"FRAMEWORK","messages":[{"description":"No data."}],"severity":"WARN"}}
Of course, my input JSON is probably not correct, since finding good reference for this has been difficult.
Any pointers to additional test scripts, or docs will be a great.
michmcda,
 The documentation is lacking. Are you utilizing the api-explorer built-in to Firepower? I ended up do a lot of trial and error with Postman. Check out the links below too. Also, you can post your JSON syntax, so I can look at it.
Postman:
https://www.getpostman.com
CDW Blog:
http://blog.cdw.com/security/programing-ciscos-firepower-6-1-rest-api
michmcda,
To be sure of your code can you also provide the script you are using? Couple pointers:
The method should be PUT with the request URI :
/api/fmc_config/v1/domain/DomainUUID/policy/accesspolicies/id_of_access_policy_you_are_editing
A JSON content example would be :
  "name": "Access Policy to Edit",
  "description": "Test REST API policy",
  "type": "AccessPolicy",
  "id": "id_of_access_policy_you_are_editing",
  "defaultAction": {
    "intrusionPolicy": {
      "id": "id_of_existing_or_new_intrusion_policy",
      "type": "IntrusionPolicy"
"type": "AccessPolicyDefaultAction",
"logBegin": "true/false",
"logEnd": "true/false",
"sendEventsToFMC": "true/false",
"action": "any_allowed_action_enum",
"id": "id_of_default_action", "variableSet": { "id": "id_of_variableSet_to_be_added", "type": "VariableSet" }, "snmpConfig": { "id": "id_of_snmpConfig_object", "type": "SNMPAlert" }, "syslogConfig": { "id": "id_of_syslog_object", "type": "SyslogAlert" }, } }
Hello Jason,
Can i have a script which will add/remove rules in an ACP from Excel/CSV.
Looking forward for ur response.
Ismail Kalolwala
kalolwalaismail@yahoo.com
got it working..thanks
Hello Prahant,
Can i have the script which adds/remove rules from ACP.
Ismail Kalolwala
Hey Mate,
Need your help please! I need to import pre-filter policy. Do you have any script for the same ?
I have retrived ACP sucessfully using your script , thanks to you.
I have migrated ASA to FTD and all policies have been migrated as a part of pre-filter policy. its good to import all of them in an excel file for futher reading.
Thanks for your help
Hi Jason,
Wonderful idea, and it's feature that sound be in the FMC, in my opinon.
However, I am having trouible getting it to run. I have python v3 running on my Windows 10 laptop and get syntax errors when running. Do I need to use a different version of Python?
John
